TheBlackSheep said:and just curious what tire is 15.5? thats really a wide tire
Interco makes some Swampers and others in that size....not meant for an XJ IMO
XJiggy said:Is there a brand of trans case drop that is recomended. however i assume that it is pretty standard the only difference being ammt. of drop.
Also about tires 32's is what im looken for any suggestions?
(i know i got one suggestion earlier in this thread and Iam looking into that one)
thanks
KarlVP said:I don't reccomend a T-case drop at all. Why even lift your Jeep if you are doing a t-case drop? You spend all this money getting your Jeep's ground clearance higher, and then you lower the belly pan?
Just do a Slip Yoke Eliminator kit, and do it right. Why even lift your Jeep, if you are just lowering your drivetrain??
LilRhodyXJ said:also I recommended TruXus MTs to you but I have never seen them in a 32" flavor...Maybe I never looked hard enough but I think their only thing that resembles a 32 is a 265/75r/16
Everyone has different tire needs as well...do you sand/mud/rocks it all depends...also I'm assuming you want a somewhat quite ride??
Mts are loud I'm not going to lie...when someone says their MT is quite its in relation to MT quiteness..Im pretty sure you can expect a Goodyear Wrangler MT/R to be louder the a goodyea wrangler gs-a(stock xj tire)
but TruXus are quite for the most part and do real well in rain
also I've been told that the Maxxis Big Horns are a hell of a tire for the price as well...give them a look-see
Andrew
