Re: Official September Rig of the Month submission thread
Submission #1
96 cherokee classic
4.0
aw4
np231
36" iroks
15x8 allied 32 bolt black beadlock wheels
trussed Dana44 front
out of a 1987 jeep j-10
chevy half ton disc brakes
yukon 5.38 gears
30 spline lock right with titanium cross shaft
30 spline alloy/chromo shafts with yukon super joints
warn premium locking hubs
rockkrusher diff cover
high clearance control arm brackets
custom over the knuckle, inverted "T", one ton steering using chevy tie rod ends
u bolt style pinion yoke
Dana60-2 rear
out of a 1973ish international milk truck
caddilac eldorado disc brakes
yukon 5.38 gears
strange engineering 35 spline spool
35 spline moser alloy shafts
whole milk friction modifier (increases locking action of the spool)
SOLID diff cover
ruffstuff antiwrap leaf spring perches
high clearance shock mounts
2" lift coils
custom longarms using a mish mosh of 7/8" heims, currie jhonny joints and ol' fashioned bushings (radius arm)
tnt customs heavy duty trackbar w/ brace and 1/2" bolt mod
10" travel edelbrock ias remote resi's in front
8" edelbrock ias outboarded shocks in back
fancy front brake hoses off of a late 70's dodge van
dodge dakota rear brakeline
bastard leaf pack using all re leaves (from a 3.5" and 4.5" pack
1.5" rocky road outfitters lift shackles
dpg adjustable bumpstop plates
progressive poly bumpstops in back
progressive prothane bumpstops in front
tnt customs unibody stiffeners
custom flat belly skid/crossmember
2x6" rectangle tube front bumper/crossmember
custom 2x6" box tube rocker panels
high clearance fuel tank tuck w/ skid
heavy duty sye with stock front cv shaft in the rear
t-case is clocked for flat belly
10lb co2 tank
grand cherokee 60/40 split rear bench seat
sweet jvc hd radio
doorless mod
