voudoux
- Piedmont NC
Trying to upload photos to photobucket ,Friday afternoon must not be a good time,will keep trying . Thanks
Here are the photos of the velocity stack that everyone wanted to see. Notice they are not under a tree in the backyard on the picnic table. http://s44.photobucket.com/user/Dancingtwins/library/?sort=3&page=1http://s44.photobucket.com/user/Dancingtwins/library/?sort=3&page=1
Hate to tell you but that's not a velocity stack. That's nothing more than a metal coupler to hook a rubber hose to.
Here is some info about velocity stacks,
https://en.wikipedia.org/wiki/Velocity_stack
As you can see yours has none of the smoothing and straightening out of the airflow that characterizes velocity stacks.
How can i say it doesnt? Because it is not a velocity stack.How can you say it does not smooth and straighten the air flow,it is smooth and straight and you have a picture of it to prove it,it does not have a bell mouth but one is formed by the stock 4.0 rubber conecter, it does not have to have an inside taper as the one on Wikipedia to be a velocity stack. What did you expect it to look like?
Do you know why velovity stacks have the bell and taper? Its to gather air and smooth out turbulence.
What did i expect it to look like? Some form of resemblance to a velocity stack would be nice. Not some random piece of tubing you found on your shop floor
What you said is correct to a point,check out the stacks on the hilborn fuel injection and the ones used on the early big block chevrolets that were different lengths.most of these were straight tube . Weber stacks apear to be straight,along with holly carbs stacks for the 500 cfm 2 barrel. Most of these had a flare or slight bellmouth to smooth out the air flow into them. My "part" was a 2.6" straight tube to lengthen ,smooth and help straighten out the air flow that used the shape of the rubber as sort of flare, what would you call an part that did these? I am sorry if I used the wrong terms,just trying to share hands on experience with others. Never again.
I just google image searched all the examples you just gave, and every single one of them has elements your tube is missing.
Did you see straight non tapered tubes,did you see tubes that were angle cut did you see tubes .that the flare was a separate piece? My part was a straight,tube with the shape of the rubber conecter forming a flare or smooth transition into the tube. I do not understand what I did that was so bad or wrong. In my view it is a type of velocity stack,in your view it is not, I am sorry if this offended you or any one else. You do realize that the idea did not work,I am not claiming it did anything, so why is my view of my part as a velocity stack so important and disturbing?
