Digger87xj
- Buffalo Creek/Lakewood CO
You need a new torque converter. Hands down.
The tranny runs cool on the road but as soon as I get in stop and go or I'm crawling along a trail it gets too hot.
This statement right here tells all.
The torque converter is causing the heat from too much internal slippage. It doesn't go into lock up in these situations and this is where you say its getting too hot.
QFT.
On the trail in 1-2 it stays in lock-up all the time with awesome compression breaking(better than my other XJ's). I don't feel any slippage.
Torque Converters can still work when they are going bad....for example, my super duty kept getting really hot but worked fine. It turned out the torque converter was indeed bad, put a new one on and it was perfect.
you are not in lockup until after 35 mph, and only after 2nd gear is achieved. Never will it lock in 1st..
If it were, it would stall the engine, just like a vehicle with a clutch, and you didn't dis engage it.
Let's organize the troubleshooting:
You report the transmission temperature gauge reports the transmission is running hot.
Possible causes:
1. The temperature gauge is faulty and reading high
2. The cooling system is not working.
3. The transmission is putting out excessive heat
Case 1:
Have you ever checked the temperature with another thermometer? You can use an oven thermometer or IR pyrometer for a quick check.
Case 2:
The cooling system will not work properly if either the airflow or the ATF flow is reduced.
Have you checked the actual airflow through the ATF cooler? Mine wasn't blocked by mud -- it was blocked by bees! The car had been driven through a swarm of bees and they completely blocked up the airflow.
Have you checked the rate of flow of the ATF through the system? I found a kink in one of the hard lines near the front of the engine on one car, in a spot I can't imagine how it got kinked. But kinked it was and the flow was only a small fraction of what it should have been.
The most convincing place to check for flow rate is the return line right at the transmission, because that will reveal any blockage anywhere in the ATF cooling system.
Case 3:
I don't know how to measure the heat output of the transmission/torque converter -- some one else will have to chime in on this subject.
My tranny shifts and operates as it should. If I felt like the tranny was bad it would already be out and the low mileage 96 AW4(90k) that I have sitting in the garage would be in there already!
Fix the fan clutch and after the flush, if it is still an issue, swap the torque converter out with the one you have in the garage (if it has one) before swapping transmissions.
