If you get just the Rusty's bar it has a tie rod end, if you get the whole conversion with a new mount it has poly bushings on both ends. If you have less than a 5" lift and 33's don't buy it, you will regret it. It will hit the oul pan and rub on the diff, and that's with stock arms, with longer arms it would be a bigger problem. It is a good bar, just wrong for a small lift.
The Iron Rock is the same but with better bends for a smaller lift and the kit with the bar and mount, wich I now have, has poly bushings on both ends. The whole package is a deal and a half in my opinion.
