To-Do List
Fix OBA air leak - DONE
Track down some annoying rattles - DONE
Tighten bolts, grease joints, maybe paint a few things underneath
Change oil and front diff fluid
And MAYBE, just maybe put a winch on - POSTPONED
front pinion seal
t-case output seal
traction bar (just the bar, mounts and crossmember are done)
mount front airbumps
mount rear poly bumps
mount rear shocks and shock hoops DONE
weld in sheet metal for bed floor HALF DONE
swap durango steering box from xj to j10 DONE
new power steering hoses DONE
rear bumper
put offroady stuff in my carburetor
traction bar, rear bumps, and maybe do the seals tonight.
front pinion seal DONE
t-case output seal DONE
traction bar DONE
rear bumper
steering stabilizer?
swap in an xj steering shaft?
front bumper?
if the weather holds up this weekend, i should be in good shape.
traction bar DONE
mount rear poly bumpsDONE
weld in sheet metal for bed floor ALMOST DONE
rear bumperDONE
Front limit straps.
steering stabilizer?DONE
front bumper?
Front shackles?
I think im in pretty good shape.. ran out of shielding gas, so no more welding this weekend, but i really only need to do a little more sheet metal work on the bed and add front limit straps and bumps. Tomorrow i have enough bolt on stuff to keep me busy and i can clean up the workspace a bit.
traction bar DONE
new power steering hoses DONEh
rear bumperDONE
put offroady stuff in my carburetor DONE
Front limit straps.
swap in an xj steering shaft?DONE
front bumper?.
Front shackles?
Spare tire mount?
new fuel cell?
All i have left to do is half ass some floors and set the timing on my engine. Oh and fix a small coolant leak.
I'm gonna try and get tuesday off of work.
I also need headlights, one of mine blew out. Might not make it guys
i see what you did there
this man is experianced with coolant leaks
im sorry couldnt resist ill go back to my nerd hole now
Gonna swap over my steering wheel to the new one and fix the clock spring today after work.. I'd like a horn for the drive down. Gonna change my front axle oil too, I'm still running the break in oil.
Don't worry about the winch, I can pull you out everytime you get stuck!:rolleyes:
Install rear locker DONE...now have to take it back out since it's not working correctly....(n)DONE (Again...)
Redo Brake Lines DONE
Install LCAs DONE
Cut Fenders, Cut+Fold rear quarter panels DONE
Install Flares DONE
Pick up new(ish) tires DONE
Install new trackbar DONE
Install new springs DONE
Install TC skid plate DONE
Install new shocks DONE
Install Disconnects for swaybar DONE
slather copious amounts of di-electric grease around my engine bay PURCHASED
redneck alternator splash shield
seal up rear quarters and bondo Probably Tomorrow
bondo up fender folds not gonna happen...
Repaint front plastic and front/rear bumpers
Get spare tire mounted and balanced DONE
Install LCA skids Tomorrow...
Front limit straps.
Weld in tie down points in bed
Spare tire mount
Add a couple strips of angle to better mount my crossmember
Mount fuel cell?
New radio?
Vacuum interior,clean the glass, pack up.
fix tranny line
rear bumps maybe
put legit brake caliper spacer thing on and take out the shim i made
trim gas tank skid
find some d-rings
wash it, clean the inside, pack it up
Bold stuff is done.
-Install t-case skid
-Rebuild front shaft
-Hook up t-case linkage
-Fix winch - Sort of, I have power in at least
-Install passenger seat so I can pretend I has frendz
-Swap in Durango box
-Swap sway bar bushings
-Replace D30 pinion bearing half-*** style
-Swap in WJ leather seats and new carpet
-Rebuild a set of spare shafts
-Build a roof rack? - Didn't end up needing the space
-Fix e-brake - Broke the adjuster trying to free it up, so this will have to wait
-Alignment
-Lube/Check/Tighten erraythang - Last thing to do on Wednesday
I'm doing laundry/packing tomorrow, then final checks Wednesday before we head out around 8pm. I'm getting excited finally...
fix tranny line
rear bumps maybe
trim gas tank skid
find some d-rings
I was considering washing mine too, but I felt like it was pointless. You might have inspired me to make it look decent though.
I washed mine, even took armor all to the pollen covered dash. I also realized half doors make it really easy to clean out the floors with a hose too.
i'm even gonna wax it. its been sitting without any since spring... i hit it hard with dish soap after it sat all winter and you can tell the paint could use some love.
