To-Do List
finish power steering stuff - good enough
install bumpstops - fronts done
install shocks - done
register and insure it - done
get wheels and tires - done
finish the cage/bumpers/etc - getting there..
get new pass side knuckle+ball joints - done and done
route front OX cable - done
tidy up rear brake lines - zip ties! done
trim gas tank skid so the 60 pumpkin doesnt smash it - barely makes contact, so done!
crossmember+skid - got one, its at sam's house :confused1
shorten front DS done, not balanced enough to do 60mph+ but whatev
install ZJ prop valve - done
added:
limit straps - measured, gotta order
put on new steering wheel
install new radiator + tranny and PS coolers done
gotta keep adding tube and i'm good.. if i dont have a rear bumper thats fine but i want the front to be all done.
been too lazy to work on it, i like driving it/wheeling better. old rad was a factory one and was leaking pretty bad on one side. should run much cooler now with the CSF, tranny, and PS coolers. i still want to add more to the cage make a bumper before nacfest. we'll see what i get done and i'll see how it works this weekend.
Fixed the horn tonight :thumbup:
i need to do that too...only one works and it sounds like a dog's squeak toy...it's downright embarrassing lol
YESS! YOU ARE FINALLY READY TO WHEEL!
YUP
well as soon as I install that battery tray and fix my parking brake anyways.
My new horn location confers true baller status upon my jeep, it is a thing to behold.
your status claim is worthless without photographic backup
Wait for my caliper brackets to come in so I can finally get my rear axle back together done
cage? have tube/ not happening
Beadlocks? ordered
Redo steering
Get new shocks
bumpstopshave a few to work with
3" lift
buy rims or spacers
mount 33s
weld rear
build steering
- DONE Bend up harness bar and X brace for cage, finish weld and paint it (hopefully this weekend)
- DONE- Finish building 440
- DONE (surprisingly wasn't that bad haha) Get 440 to fit in engine bay :laugh:
- DONE - Build motor mounts
- DONE - Modify/ build crossmember, transmission mount, NP205 rear mount
- DONE - Redo traction bar crossmember mount (move to passenger side)
- FRONT DONE - Build new driveshafts
- DONE - Mount radiator, plumb cooling
- DONE - Build exhaust
- T-case shifters
- Mount pistol grip for NV4500
- Center console and transmission tunnel
- Slave cylinder mounting/routing
- New dash and gauges
- Megasquirt and TBI
- Adapt throttle bodies to intake
- Build throttle linkage/cabling
- Build air box/cleaner
- Build wiring harness
DONE - Seal up/paint NP241/NP205/NV4500
Just added some stuff to keep track of it.
not that anyone cares but im replacing the radiator & throwing out the ac this weekend, tired of carrying it around....
crossmember+skid - done
limit straps maybe i'll buy some
want to do.. front bumper, rear bumper, tube on sliders. we'll see how much gets done there.
need to adjust or make a new tcase linkage too.
wheeled the shit out of it with UJ this last weekend and found out that my pass side lower balljoint in the turdy is literally hand tight in the inner C, it fell out like 1/4" when I pounded on the knuckle with my fist. Pretty sure the inner C is just wallowed out.
I'm having a hard time justifying spending $50-130 on a new 3.55 30 for it when I have a 3.55 rear 60, a 3.55 front 60, and 8 lug rims that'll fit my tires sitting in the yard.
prepare for some truly horrifying hack ass shit in my build thread
You are right Chris! Who cares!:rof:
put my bed back together
take apart beadlocks and clean em up with new hardware (1/4 done)
install shock hoops and rear shocks
install all the fuel injection shit, including cell and whatnot.
and then theres the optional stuff...
fully box the frame
belly skid
rock sliders
traction bar
front bumper
hula girl on the dash.
instead of being gay and putting "done" i just deleted the shit thats done.
hula girl should not be optional
