xjbubba
NAXJA Member # 1524
- santa barbara, ca
Thanks for the input, Hinkley; no doubt a large enough(?) MIG will do the job, and will do it faster. Since I have more experience with TIG, i.e., I can "feel" and see when my "bead" is adequate, I feel more confident using my TIG. I'm just now learning to use my new MIG (a Lincoln 175, 220V).
One Ton, I hear you on using a short back cap and tungsten when working in confined spaces--I tend to "contaminate" my tungsten too often to use the short back cap all the time! The most frustrating project I undertook was major mods to the front frame rails to accommodate the install of a Chevy 350. The rust proofing on the rails (galvanizing?) would frequently pop, with instant globs deposited on the short tungsten--requiring me to grind the contamination off before continuing, leaving the tungsten too short for the torch. This problem occurred most often where two layers of "frame" overlapped and prevented me from properly cleaning the coating off before welding. I've noticed with my MIG I can weld galvanized components without cleaning with no apparent bad affects, other than gnarly, unhealthy fumes. I don't like welding galvanized, but I needed a nut tacked to a plate to be used as a tool to solve a "right now" problem. Using my TIG would have required I grind all traces of galvanization off of the nut or risk instant contamination of the tungsten. Since I was in a hurry, and the job was small, I broke out my new MIG. The results were very satisfying.
