Headed over to the shop the morning, and ended up having a pretty productive day.
Driver seat is in. You can see the rail it slides on for adjustment between drivers. Smaller tube being 1x.120 DOM, and the outer tube being 1.25x.120 DOM. Still need to drill the slide, and add the lock pin.
Putting the final touches on the passenger side seat brackets. This side is non-adjustable, they're in it for the ride.
TIG magic.
We drilled out the frame to weld in some 3/8 tubing, which we then tapped out to 1/2-13". This is what the front seat post bolts to. Our goal was to have almost all the interior brackets and support tube removable.
Seats are in. The seats themselves are from Twisted Stitch. You can see the adjustable seat cushions on the driver side. We have 3" of adjustability for different height drivers. These are by far the most comfortable suspension seat I've sat in.
Joey was also out at the shop today plugging away on the dash. He's keeping a lot of the original, which should be pretty cool for the "Comanche" theme we're trying to stick to.
TIG magic.
