New plug wires. MSD 8.8mm, surprisingly a lot nicer than the Moroso parts they are replacing.
I have 2 8" heater hoses that basically run to the temp gauge and idiot light, and back again. The hoses were starting to get old and crack, and were the only non silicone hoses on an otherwise nice car, so i replaced them.
Are hose clamps typically an issue? I've never had one fail.
I have a truck sitting in my bay right now with two zip ties holding the lower radiator hose on. it came in for leaking coolant. It's leaking from the cap/surge tank though :dunno: it will be getting clamps before it rolls out anyways.
What the factory uses.
Spring clamps are the devil.
If you had suggested these I would have been on board, but no, you went with the things that make me cuss and give factory engineers the finger.
I see none of you understand why the spring clamp exists.
Because it's quicker for the OEM to install at the factory and cut down on assembly time? Obviously if it were a function issue the best clamp would be a band clamp, as seen in after market high boost turbo applications.
Its not a matter of understanding why they exist. Its a matter of understanding their failure mode when being field serviced.
They have no place on a race car.
Or trail rig.
Or expedition rig.
Or margarita machine.
