- Houston, Tx
The main issue IMO is that you're running stock rims, which will cause even thsoe 31x10.50's to rub at full lock. Spend the $200 and pick up some 15x8's with the proper backspacing.
Here's my rig. RE 3.5" with a .75" coil spacer on the front, and a Ford 8.8" Rear (adds about 3/4" lift to the rear). I run 31x10.50's on 4.10's with a 5spd, and if I did it again I would have gone 33x12.50's, I do alot of sand and surface area is your friend.
you can see with the amount of space I have, 33's would be no issue.
