jeepguy97
- clearfield, pa
Besides the obvious handling issues, will removing the front sway bar have any negative affects? Like will it stress the track bar any. Comments welcome.
sure he will notice a difference, but when i ran without one for a few months and then put on quick discos, i noticed a distinct differnece in the ride. before it floated over bumps much better no it kind of absorbs them roughly. at least i can corner fast now though. but yeah, to wrap up what i said, there you godizzymac said:Don't remove it, just get quick disco's. You'll see a noticible difference in handling if you remove it.
Driving without the swaybar is similar to the rollcage
jeepguy97 said:I don't have a roll cage.
bgcntry72 said:Anyone know where to get end links.
I had one break off and have been sans-swaybar for a month now.
Not my ideal way to take the kids to school.
TIA.
gjxj said:Ok, my guess would be if you have a rear and you remove the front you
should also remove the rear.
Minor technical correction, Mark. The rear sway bar was never optional on the XJ. There was never a place on the order form to check off if you wanted to pay extra to get a rear bar, nor was there ever a "delete option" you could check off to tell the factory you didn't want it even though it normally came on your model.Lawn Cher' said:Front is being discussed here. The rear one is optional from the factory, which should be a clue as to its usefulness.
