Steering Conversion...
AboveNBeyond
Northern AZ.
Hello all,
I will be needing to do some front end work here soon. When i do I was considering the steering upgrade where one tube goes from one knuckle straight to the other. And one from the right knuckle to the pitman arm. I do not know if there is a name for that set up so I cant search for it.
If you know what I mean can you please tell me the name or a link to a conversion would even be better if you know where one is, but with the right name I can search too.
Thanks.
http://www.tntcustoms.com/page.asp?pageid=178
Lots of others make them. Or you can buy the rod ends and fab your own. JKS has most of the parts in there builders parts page. You might try searching here for WJ swap or upgrade. It will upgrade your brakes to Grand cherokee brakes as well as the over the knuckle steering. But it pretty costly and time consuming.
:peace:
