jeepguy97
- clearfield, pa
Tow Points--they make life easier especially on XJs.
bgcntry72 said:Custom stepside bed that screams vintage 'Willys'.
:laugh2:
Danno said:Jes, you advertizing what you ain'tgot?! :viking:
I've been thinking about getting that 2lo conversion. I hardly actually need 4 lo all I need is the torque. Was it easy to install? Do you have to completely disassemble the t-case?Goatman said:Well, for awhile I said it was gears, but then I installed a 2 low conversion, and I definitely thought that was the best mod that I had done. After stretching a chain in one year after installing lockers front and rear, the 2 low has really paid off, and I haven't stretched another chain in over 7 years. Plus, the ease of driving in tight sections of trail, and the fun factor put back into trails running mostly in 2wd make the 2 low a winner.
But, now I couldn't tell you what the best mod is. I could say chopping the back and making a Cheromanche....definitely a good thing, or installing a rear Tera60R....major peice of mind. The 2 low is still way up there, though.
hoytinak said:i'll have to go with my winch....saved me a couple of times when i was out playing around by myself
BornAgainXJer said:I've been thinking about getting that 2lo conversion. I hardly actually need 4 lo all I need is the torque. Was it easy to install? Do you have to completely disassemble the t-case?
junkxj said:1-2 switch and tourque converter lock up on aw4
casm said:Just out of curiosity... What's the single best mod you've done to your XJ and why?
