Capt. Nemo
NAXJA Member #904
- Southwest, US
I'm NOT talking about this:
For the most part, the trails that snake through the Sierras have already been "groomed" with strategically placed rocks so that the averagely equipped rig can make it over an obstacle without much effort. Spend any amount of time on the OHV trails in the Sierra Nevadas, however, and eventually you'll have to stack a rock in order to get over an obstacle. It may be for you, it may be for a buddy, it may be for a complete stranger... either way there are some common guidelines that should be kept in mind when stacking rocks:
1) Only stack rocks if you intend to remove them when the vehicle is over the obstacle.
2) Only stack rocks that you can physically place and remove.
3) Only stack one or two at a time until the vehicle is able to move over the obstacle.
4) DO NOT stack in areas or lines that are considered "optional", "driver's choice", or have easier [legal] bypasses around them. If you can't make it without stacking, you don't belong there in the first place.
5) Did I mention, REMOVE ANY ROCK THAT IS STACKED!!!
What brought this thread on was my experience on the Barrett Lake Jeep Trail this past weekend. I was absolutely floored to see a challenging optional area completely paved overnight - literally. I didn't have the hour or so of time to un-stack all of the rocks, unfortunately. In addition, I observed two guys roll an Igloo cooler sized rock into an optional area, making the line over challenge not a challenge at all. I hollered at the guys to remove the rock (which they couldn't budge after they rolled it down hill), but they just left it.
Here are some pictures:
BEFORE. Notice the rock wall on the left side of the picture, and the large rock in the center of the picture as my buddy takes the line of this optional obstacle:
AFTER. This is the same obstacle 24 hours later. Notice all the rocks between the wall and the large rock. It looks like a dump truck unloaded right there. The challenge is now almost no challenge at all.
If you have to stack, REMOVE the rocks when you are done. If you can't make an optional challenge, LEAVE IT ALONE and go around.
