GroversXJ
- Peoples Republik of Kalifornia
I am installing a waggy d44 into my front end and in the process i've raised the lower and upper mounts on the axle to try to minimize my short arm angles for a better ride. I put the axle under the jeep for the first time after tack welding the link mounts on and it looks like I may need to lower my upper mounts on the axle by an inch. So I measured the upper arm angle at 7 degrees. What angle does the stock control arms sit with no lift?
