Jeepedo129
- Henderson, NV
Alright, So tis the season to spend your tax return however, Im stuck with a little bit of a dilemma. I've been scouring the interwebs to find as much info and several different avenues to spend some money to upgrade the Jeep.
My main Dilemma is the ARB locker. From what I've been able to find, There isn't an ARB for the dana 30 for 3:55 gears, all Ive found is 3:54 and down, or 3:73 and up. Preferably I would like 3:55 and up, but I'm sure something like that doesn't exist due to carrier size. Just thought I would ask. I would upgrade to 4:56s but Im not really in the position to do that at the moment because the 33s I have in my possession aren't mine:bawl:......yet. If this cant be done then I'll move on to the next.
Next is I would ultimately Like to put a D44 in the rear, probably from an MJ that is sitting in the PNP yard. From what I've read, 44s have more aftermarket support and a little cheaper to maintain. BUT I have ZERO experience with 44s so I don't know if there is any truth to that. I already have a Chrysler 8.25 that is a 29 spline and was wondering if it is worth the trouble of finding a 44 swapping it in with perches and shock mounts just to have one more spline thats only 11% stronger OR just keep the 8.25. The biggest tire I want to run is a 33 and I'll want to lock it up with an ARB.
Next If neither of those work out, I'll be going with a long arm kit. I like the TNT kit, mostly for the belly pan, but there is a guy in Lehi Ut that has his own business and he makes a decent radius arm set up for around 650. Either that or the Serious Offroad kit. And ill do a steering upgrade in the front. Anyway Im rambling and I'll stop haha.eace:
BTW Im running about 4.5-5" of lift at the moment with SYE and extended Brake lines and frame stiffeners.
