XJ longhouse
- Grapeview, Washington
here she is, still need to take the beadlocks off the rear,
skinny boggers on aluminum rims might last reasonably on a built D30...As long as any heavier 37 would anyways.
dont supose you noticed the spring is unseated by about 2 inches in front :cheers:
Awesome? :cheers:
Limiting straps depend on what's currently limiting your suspension from going farther. I would say yes. I'd limit it just before it unseats the coil.
you are still going to have hell with that D30 and those tires especially if you get into a bind.i have 8 of them so i figured id make them work, 4 are new, 4 are 50%
:dunno: id say nothing is limiting it right now, havent got shocks on it yet, i have a set of 14" travel shocks from the toyota crawler that are 35.5" extended, gotta see if they'll work up front , guessing they're to long, but might custom mount them so i can have limited up and lots of down travel
Could go to the junkyard and snag some seatbelts. Most strap kits are basically the same thing.what companies make strap kits?
quoted for truthDo whatever you want. You are going to anyway.
