- Patterson, Ca
38's left from a Toyota project, so I doubt he's new to wheeling. I'm trying to help people avoid the situation I'm in with a pile of cash into stock axles and 35's when they want to go bigger. Swap in 1 tons from the start, d
were stupid though.
... I pretty much disagree with all of this actually. Only reason I'm not building the 44 sitting in my yard is I'm not sure whether I really want to put money into it vs the 60s sitting in my yard*. And 31s are damn near stock, I've put em on the back of a stock MJ without even trimming.Maybe it's the small wheel openings, but in the xj world, it's seems people think of 31's as big and 35's as huge. A Dana 44 is considered the biggest axle you could ever need. It's like a time warp to wheeling in the early 90's. People read half a thread and then quote your specific post with irrelevant comments. He's got 3
I am not a betting man but I disagree. Everything except the shafts is clearly stronger but I'm honestly not sure if I'd put money on an RCV shaft vs a stock 60 shaft with 806 joints in it.Sorry for the triple post, dumb smart phone. Don't even need to beef up the 1 tons to run 38's on a light xj. You could swap in a set of tons for what some guys spend on axle shafts. I'd bet money a stock Dana 60 front is stronger than an rcv equipped, trussed, sleeved, $4k plus Dana 30.
im gonna be running 38s on a ford 8.8 rear , anybody done this? just wanna know how its gonna hold up, diff is limited slip for now
Going big on tires is a waste in my opinion, I just did a black diamond trail in my xj with a 4" lift and 31's with my buddy in his tj on 35's... And I lead the trail the entire time and had more fun doing it this is just my opinion but im a firm believer that driver expierence out weighs rig size... Someone that can pick their lines and have proper tire placement can go just as far If not further than someone with no expierence and big lift/tires... Just my opinion thou!
I can do that with an XJ on 28s without even putting it in 4 wheel drivethou opinion est incorrect.
please tell me how an XJ with 4" lift and 31"s does this?http://www.pirate4x4.com/forum/showthread.php?t=582038
with a helicopter
Start with the parts that will work with your end goal.
more here
Please show me an XJ doing this trail in these pics
Hey I would a least try those trails if i was in a situation to where i had to do it... but I'm smart enough to know when To call it quits... All things aside... I believe Driver expierence is more important than rig compatibility...
Well I got the long arm on and the 38s has about 5" lift, so its lcg for its size , no rubbing , the tire still drops below the body completely in front while flexed, I need to invest in a limiting strap setup,
I didn't want to do 1 tons because I wanted it to be street legal still ,
I'll get pics up soon ,
And I know people talk crap about the 8.8 factory limited slip , but mine hooks up real good, even with 38s , I let you all know when it fails
