I'm confused. To the people saying it's a manufacturing defect...when did Rock Kraler start manufacturing heim joints?
What size heim joint is it anyway?
And as far as "precisely measuring the thread size"...give me a break. If it threaded in, it was the right one. Not passing judgement on what happened here but nitpicking safety nazis are almost as annoying as the whining OP.
To the OP...before you drink a pot of coffee, take some non-blurry closeup shots of the inside threads on the trackbar, that's really what we need to see here.
Then please, by all means, OP PROVE that part of the trackbar failed (eg: stripped threads on either component), because if the threads are still intact, then it was your negligence when installing it to not notice the parts you received did not fit together correctly, not the manufacturers. Yes, they may have sent you the wrong heim end joint, but you installed it that way - now it's on you.
Sorry to be harsh but sometimes the truth hurts
no the stering stabaliser is conected to the RR HD steering..... and yes the jamb nut was tight and it was threaded almost all the way in..... now i dont have the part nuber right on hand but i do know that the track bar was there bomb proof track bar for 6.5 top 8.0 inches of lift..... Realy Im a little upset about almost dying but i have had parts fail before and thats not what upsets me.... Its that RK stated a life time waranty, but when I call with an ovious manufactured defect they insinuate that im the moron for not tightning down my jamb nut..... what ever.... im just trying to warn others of the potental falier in the track bar and the supper $hitty customer service.... and I after closer inspection the hime is to small for the threded part on the bar....... o well
any one want to buy a slightly damaged rk track bar for 6.5 to 8" of lift?:laugh3:
He said it not me
:shhh:
What is that like 3 threads?
Just asking.Cause thats all i count with my old eyes.
Crappy picture, can't tell from that view. The shank on the heim looks like it had at least 10, but that could be glare as well. Need more detailed images of the bore of that tube else it is meaningless.
I'd bet the extra 6-7 threads that look shiny on the heim are from the nut and not from the tube.
