Jeff in VA
<---respect
- Richmond, VA
Finally got mirror relocation brackets for the TJ so I can run doorless. Installed them Friday after work, and was taking the steel half doors off and did a stupid move. Pulled the passenger door off and set it on the step rail to get a better grip on it, and then proceeded to lift it by the soft upper and it fell straight to the ground. Problem was, I was wearing flip flops instead of my steel-toes, and crushed a couple of toes and 90% amputated the tip of my second toe.
911 call (I was home alone), ride to the hospital in the meatwagon, 5 hours in the ER with IV antibiotics, 12 stitches through the nailbed, and got back home about 9 PM that night with a bottle of percocets and some antibiotics. Oh, and I almost forgot.....a teatnus shot just to round everything off.
I go to see an orthopedic surgeon this week, hopefully I'll be able to keep the toe tip that they sutured back together. That toenail is gone, and I might have to have the big toenail taken off too if the pressure underneath it doesn't start subsiding. I'll post up some pics if anyone is interested.....
Jeff
Lesson: even the simplest of things can go very bad if you aren't thinking about what you're doing
Jeff
