To simplify -
Faster box = less torque multiplication
Slower box = more torque multiplication.
TANSTAAFL. You can't have it both ways - you have to trade something for something else.
In the case of an off-road rig, you're going to be better off with the slower (numerically higher) box. For a rig that barely leaves the pavement, the faster (numerically lower) box will serve you well.
Why did I want to put a faster box on my wife's rig? To give her more options when it came time to take evasive action (just like I wanted to regear slightly - 3.55 to 4.10, to make the rig a little quicker on the go - and give her four-wheel disc without ABS. She learned to drive like I did - we think safety lies between the ears, and she was trained again in the Academy, even if she didn't take EVOC.)
If you're off-road, especially crawling along, you want the slower (numerically higher) box to reduce turning effort at low speeds.
In either case, I'll recommend at least cross-bracing the front framerails to each other, if not tying the framerails together, adding a reinforcement plate to the gear mounting, and tying the gear body to the opposite framerail (the brace used in the F-body is enough for the F-body, but we're going to put a lot more force on things - larger tyres, more stressful turning environment.)
While not as nimble, a 16:1 or 18:1 box will work neatly for what we want to do off-road, and bracing the framerails and/or steering box would be considered necessary at that point (not only will you be stressing the mounting point severely, not making the front subframe rigid will cause "steering wallow" and effort will be wasted in bending the subframe instead of turning the tyres.)
