The best jackstand points on the chassis are as follows:
FRONT--right behind where the lower control arm bracket is welded to the "frame" rail
REAR--inboard of where the front spring hanger bracket is welded to the "frame" rail
What XJ-Unlimited is correct. I was assuming you were looking for the "jack points" on the chassis. If you are placing jackstands on the axles, as far out on the tubes as you can get will be best.
