fdsa487
- El Cajon, a.k.a. The Box
I would rather get longer JKS Quick Disconnects. I hate the ones thare are on there now anyways.
Rock Yacht makes the TNT kit, so if he says it completely bolt on they must be.GroversXJ said:2 questions/comments
First, I though that on the TNT kit you had to weld the sleeves thru the unibody frame to the frame and when the kit came out that only TNT would do it, but they may have changed some things.
Second, how would extending the sway bar disconnect buy you anything more than positioning the sway bar further up in the wheel well, because its the torsional stiffness of the sway bar what actually resists body roll.
Please educate me.
RCP Phx said:Adjustable arms won't do a thing for the angles!
Please educate me.
Please educate me.
I must have understood it wrong.Martinida said:Rock Yacht makes the TNT kit, so if he says it completely bolt on they must be.
I'll buy that they keep the sway bar further up away from the springs, but it wont make the rig have less body roll.Martinida said:Longer disco's mean better geometry which will hopefully keep the the SB outta the springs and be less likely to rip the SB mounting bolts outta the frame.
How does it make it less effective?ECKSJAY said:B) Those swaybar endlinks are WAY too short...which makes your swaybar less effective.
