yossarian19
- Grass Valley, CA
I partially agree with this. As I understand it, fan blade design affects the efficiency of the fan as a system to move air, that is true, HOWEVER it does not allow for the fan system to do more work than the energy it takes from the engine. No blade design can make a fan do more work, it can only increase the system efficiency thus allowing the fan to not waste as much of the energy being used to turn it.
1 HP is around 700+ watts...and some of these fans are 80 watt (like the DBO fans).
In the electric/electric comparison, the motor will not be able to do more work because of a more efficient fan blade...the more efficient fan blade will actually have to spin slower than the inefficient fan making the air moved equivalent. Regardless of the rpm the fan blades are smashing into air molecules and it requires work to move the air. More air pushed, more work done, more amps drawn (or higher voltage used).
Ultimately there is a theoretical maximum amount of air that can be moved by a 100% efficient fan motor and 100% efficient fan blade at a certain wattage. I DO agree that replacing a 50% efficient fan blade with a 75% efficient fan blade on the same motor will move more air while using the same amount of power...but it's only because it is losing less...which I guess is more or less what you said, Yossarian.
Jeez I can say a lot without saying much of anything, lol.
Yeah, we agree.
