child9
- Austin, TX
^ this.
The more I look at it, the more I am leaning towards the math. OEM clutch fans simply move a LOT more air than electrics. This means they do more work, cool better (unless at idle), which means they require more power. I suspect the power-to-rpm relationship is very similar to that of drag, being exponential in nature. The electric fans do less work and hold a constant rpm and therefore require less power to run. Conversely, the OEM fans cool better (unless at idle) due to significantly higher CFM.
Personally I would run an OEM clutch fan if I could. In fact now that I just wrote all that, I'm going to revisit fabricating a new fan shroud that will mate the stock 2JZ clutch fan to my Jeep radiator. (I use the term "mate" loosely)
