Markos
- Seattle, WA
All:
I'm puting together an OME lift. If I don't buy it online from one of our well known OldManEmu retailers, I'm going to peice the kit together myself. I'm still waiting on a quote from one of these retailers...
I was thinking of spending $99 on Rusty's 2" coils versus 930 coils at $299 plus a $30 spacer kit. I called Rusty's this morning, and their 2" springs have a rate of 150lbs versus 160lbs for the 930's. Regardless of coils selection, I will be using OME shocks...
I've read good reviews of the 3" Rusty's spring. Any comments on my OME/Rusty's Hrybrid setup?
Front Coil Springs:
OME Part #___Application_____________Rates_______Free Height_____Est. Lift
OME930______Light / Standard Load_____160 lbs/inch__18.7"____________1.75"
OME930______Heavy Load_________________________________________1 - 1.5"
OME 931_____ZJ I6___________________140 lbs/inch__20.08"___________1.5 - 2.5"
OME934______ZJ V8________________ _180 lbs/inch__20.08"___________2 - 3"
OMEJGF10___Trim Packer_________________________10mm
Notes:
1) Left and Right springs typically have a 12mm Free Height difference to compensate for height or load variations between the left and right side of the vehicle, i.e. trimming.
2) Lift is only an estimation.
Rear Leaf Springs:
OME Part #__Dakar Part #__Application________Rates________Camber__Est. Lift
JC1A_______CS034RA_____Medium Load________148 lbs/inch___230mm___3"
JC1B_______CS034RB_____Medium Load________148 lbs/inch___205mm___2.5"
JC2A_______CS035RA_____Constant Heavy Load__137 lbs/inch,
____________________________________________257 lbs/inch overload
__________________________________________________ _______235mm__2 - 3"
JC2B_______CS035RB_____Constant Heavy Load__137 lbs/inch,
__________________________________________________ _______210mm__1.5 - 2.5
JCXL____________________Add-a-Leaf __________+20%_________________1"
OMEU60_________________U BoltDana 35
OMEU57_________________U BoltChryCo 8.25"
XJGK01__________________Transfer Case Drop Kit
