cj11
- Easton Pa.
Has any one ever broke one of these bolts or adapters.
I have a 97 Xj and thought I had a rear main seal leak turns out whan I was replacing My NSS i noticed That there was not much oil on the trans inspection cover and was pretty dry up by the seal so started looking around. Found that there was fresh oil leaking from the oil filter adapter and running down the pan and blowing allover the place.
Picked up the o-ring set and t-60 torx. I have tried to break the nut free and can not get it to turntried with a open end wrench and it just bent open, then a small 1/4 inch rachet snapped it, big a$$ adjustable would not budge do not want to break this does not look like it would be an easy fix.
Sorry for rambling on just dont want to screw this up.:doh:
