badge714
- Youngstown, Ohio
OK guys thanks for info.. badge714
Good post but it's been covered.carnuck said:Just a thought, but is the flywheel the same? If it's from the wrong EFI system, it won't start ('87 to '90 Renix 4.0 and '91 up HO). If the CPS was still attached to the trans during swap, it may be wrecked.
There are 2 screws on the box. (up top)
langer1 said:This is a dumb suggestion but could you have gotten the battery connected backwards?
old_man said:I have an ECU from a manual tranny version you can borrow to try.
langer1 said:...you need to look at what things tell it not to start the engine.
Apparently, there is a coolant temp sensor (CTS) on the left side of the block below the manifolds on '88 4.0's.
(someone asked if the battery terminals were crossed)DeadEyeJ said:Now that just hurts my pride... Naw, the posts are different sizes.
langer1 said:I don't think so, theres one in the back of the head and one in the T-Stat housing.
