It will not start with a bad CPS.DeadEyeJ said:Should it start with a bad CPS?
Is there a cheap way to test the computer and ignition module?
Jared
Check them both.DeadEyeJ said:Is the C101 connector the one above the brake booster- or beside it? I have not unplugged it, but just curious.
Jared
DeadEyeJ said:Here's the deal -
I tested the sync sensor. It hovered at 5V with the key on. While cranking, the voltage drops to about 3V and stays pretty steady. Which should mean that it's bad. But I never get any spark whatsoever, and according to the info at hand it should run poorly at least with a bad sync sensor.
I did the same type of test on the CPS and did not see the needle move, but I don't think the needle could move fast enough to really show me anything definitive. I wish I had a lab scope to show a nice waveform or something. The CPS tested fine as per the tests listed in my Haynes Manual. It involved resistance across 2 terminals.
This is really driving me nuts! Should I just go to the junkyard and get a bunch of parts to start throwing at it? I hate fixing stuff by doing that.
Does anyone know how/what wires to test for power/grounds to the computer? I'm thinking that it HAS TO BE the computer or the CPS or some connection between the two.
Is there any hope?
Jared:tear:
That reading is correct, it should be very close to 0 vdc when running. Again I ask, are your injectors firing, thats where we need to go now.DeadEyeJ said:OK - I replaced the CPS. It still has no spark. So then I retested the voltages coming into the ignition control module (ICM, attached to the coil). The larger gauge yellow wire has 12.5V with the key on, and the smaller gauge yellow wire shows only .5V. Neither pulses while cranking. If my thinking is correct, the smaller diameter yellow wire is the one coming from the ECU (computer) and should tell the ICM when to fire the coil.
.5V just sounds wrong to me. Could anyone verify the correct voltage found at the smaller diameter yellow wire coming into the ICM? It's the only wire in the 2-connector plug on the ICM.
Thanks,
Jared
If this voltage is wrong, what does it mean? I'd assume that it means: 1) a bad connection between the ECU and ICM 2) a bad connection between the CPS and ECU 3) a bad ECU.
Any thoughts?
Hmm.DeadEyeJ said:I just realized that the fuel pump is never shutting off when the key is on. Either it's not building pressure, or the relay is not shutting it down when proper pressure is reached. I'll go test the pressure now.
Check the pressure but pressure is not what shuts it off, the ECU has a three second timer that turns it off.DeadEyeJ said:I just realized that the fuel pump is never shutting off when the key is on. Either it's not building pressure, or the relay is not shutting it down when proper pressure is reached. I'll go test the pressure now.
