SEXJ96
- California
Hello,
I need some help diagnosing clutch issues with my 96 XJ. The symptoms started out being what I thought was a worn clutch (has around 145K and not sure when/if the clutch was ever replaced by PO) as I would put it into 3rd gear, engage the e-brake and lift of the clutch and it would not stall. Being a college student on a low budget I figured I can get some life out of it before I absolutely have to replace it (was saving cash for it in the mean time) since I dont have access to a lift, tranny jack, etc... to do the work myself so I was going to have to take it to a mechanic. I also started noticing a squaking sound whenever I press/de-press the clutch pedal.
Afterwards, the clutch starting feeling squishy and the resistance I would feel started decreasing. Now, I can barely get the tranny into gear, I have to pump the clutch several times and that barely gets me into gear. Sometimes I feel absolutely no resistance and the pedal drops to the floor. The car is absolutely not safe to drive now and its been parked for a couple of days while I tried researching what the issues are.
I have done most of the work on the Jeep including an SYE install, however I have never done any clutch work. Perhaps a good explanation of the clutch system on the 96 and how it works might be of help. Also, being on a tight budget, I would rather attempt to solve/diagnose issues myself and if some are fixable I am willing to get them done. Ideally I want the mechanic to do the actual clutch disk/flywheel/pressure plate but whatever else I can do I would like to in order to save as much as possible.
If someone can please take the time and help me diagnose what issue/issues (Im suspecting multiple issues) Im having I would greatly appreciate it.
Thanks for all your support,
ehanania
ehanania
