mako my day
- Aliso Viejo
4:56, 32 muds. 10mpg here.
Has anyone seen gains from a cold air intake, and a 63 mm throttle body?
I put my stock airbox on, no real difference from my snorkel.
This guy has a good deal.
http://www.ebay.com/itm/Jeep-63mm-4...Parts_Accessories&hash=item19afe4d7dd&vxp=mtr
theres a guy somewhere online on one of the XJ forums that bores XJ throttle bodies for like 100$. I highly doubt a bored TB will add to MPG, probably stay the same or go down even. after i went from 52-60mm on my renix the off the line was nicer, but i didnt notice any gains in MPG.
check for clean grounds, exhaust/intake manifold leaks, vacuum leaks, test the TPS, CPS, also winter gas sucks, and that probably isnt helping. verify that all o2 sensors are functioning properly. just because some are new doesnt mean much, and the post cat sensors could still be bad as well, which I doubt would kill MPG. consider sea foam in the intake and in the gas tank. how new is the air filter, etc?
are you 100% the TC is locking up when you are cruising ? Determine if the cat is good as well, that could easily do it.
running too cold, staying in closed loop?
