srmitchell
- Mckinleyville (Humboldt) CA
My 2001, 4.0/ CA emissions, AW4, 4.56 gears, and 33x10.5 tires, is getting 10-11 mpg. 173k miles. Only 4 inches of lift, but no roof racks, and the tires are skinny, and always aired high. What the hell can I do?
The gas tank was filled last thursday, and according to my odometer, I got 150 miles until the light kicked on, and I only got to like 164 miles until it was totally empty. Since my speedometer it about 5% off, 164x1.05=172.2
So even considering factors like a less than full tank, or a faulty fuel gauge, even if I rounded up... I'm getting below 10mpg. (A full 20 gallons at 20 mpg= 400 miles, 20 gal at 15mpg, 300 miles, 20 gal at 10mpg = 200 miles)
-I have a cowl snorkel, (air draws from the cowl area below the wipers, stock air box.) True cold air.
-Iron rock offroad cat back exhaust
-All 3 cats are factory. I have replaced the upstream O2 sensors.
-4 hole Precision Injectors
-Spark plugs just changed again with the proper dual platinum for the dual spark 00-01 system.
-I have used redline's fuel system cleaner recently
-The IAT sensor is clean, throttle body is spotless, all the bearings on the front accessories (power steering, water pump, etc are working well), I remember JP mag talking about a bad PS pumping sucking mpg.
-I always cruise at 60-62 on the freeway, I don't speed.
-I'm currently not even running a front driveshaft due to a transfercase bearing issue.
Any suggestions? Is the fuel filter/sock thing worth changing? Maybe the timing chain? The cat? I've got a lot of armor on this jeep, but the numbers just don't add up.
Thanks!
Coumbus
Thanks!
Coumbus
