ericfx1984
- Kansas City Area
Winner!!
maybe I should make a similar device for the front?
Winner!!
Winner!!
I disagree. What I see is a 2" receiver welded to a class II hitch.
It would be a good idea to add a plate behind the reciever, to pick up the two holes on the rear crossmember
I disagree. What I see is a 2" receiver boogered to a class II hitch.
Fixed it for you!:roflmao:
both your front and rear stuff is borderline scary....
you guys need to stop blaming your welders duty cycle. if your rating is 10%, yet you weld for 50 minutes straight, its still operator error. would you keep pushing the gas pedal after you drove into a ditch? learn your welder better before taking on projects like this. both your front and rear stuff is borderline scary....
No, they're both scary.
The front is scary because it has two bolts and a poorly designed bracket. You must go with the OEM setup or greater with tow hooks or you're going to be very sorry.
The rear is scary because of that welded in cast tow hook. Can it be done safely? Yes. Do I trust that a newbie welder with entry level equipment can do it? No. This is not even mentioning the Class II / Class III hybrid receiver hitch that does not give me warm and fuzzies.
we have established that the front will not work... I am reworking the front, focusing on the rear as we speak... people are giving advice, I am taking it...
I did not weld the tow hook, I started with this...
http://www.google.com/products/cata...=X&ei=Bm3dTa-uHZKTtweq3sDGDw&ved=0CFQQ8wIwAA#
