greychalet
- MI
MJR=Only problem is the cutting out now, that I am aware of.
McQue said:Well...bad connections can blow a fuse...and the oil pressure sensor replacement is a common failure and fix for the sympton that the tech observed...so they were real failures and fixes, I would probably be physically looking inside the PCM to see if I could find a loose, or heated circuit component or connection that I could repair before I decided to buy a new one, if I could not figure out where to go next in the troubleshooting process...
greychalet said:Well my wife's "impression" was it started(cutting out)after I lifted it ,added dvd player,back-up camera,Driving lights.Problem is I did all of these things at same time.Literally had 4 of us.
greychalet said:I am probably going to give the stealership a shot at it but should I give them the previous invoices 2 read or just go in "cold" describing symptoms only?
greychalet said:Thank you very much .I've only got one more question will you come fix it for me?LOL
greychalet said:I definately agree with the PCM shotgunned statement .But about the radio the 2 issues have never happened simultaneously and when I blew the fuse that doesn't ship from factory? The cutting out never happened until i took it back for the gage/radio issue.
greychalet said:Whats ironic is I travel all around to the big 3 engine plants as a service tech and i am clueless auto troubleshooting.
greychalet said:I love my jeeps but computers belong on my desk.
