I have taken the hinges off a couple of times for body work and it's slow and tedious getting the doors back on straight. I wouldn't want to do it more than once a year so if you are garaged and looking for 6-9 months off then it'd be livable. Fastest easiest technique is install of the screws but keep them loose and use one screw in each hinge tighten and loosen until you have the body lines correct and the weatherstripping has full contact, then tighten everything down after. The body hinges have holes in them that you can put a driver through to loosen and tighten, although the front fenders have to be off for this to work with the front doors
yep thats what i did to fine-tweek the seal. FYI guys, i dont remember what/if any of the writeups say this, but definately swap out those torx screws for hex bolts. makes life so much easier. i dont remember what size though, ill try to look it up
EDIT: hahha so it turns out i had even made a thread asking the bolt size back in the day and ofcourse ehall had the knowledge like usual :kissyou:
quoting ehall. thanks buddy
I'm almost positive they are M8x1.25x30 based on my McMaster-Carr order history
I like the stainless steel button-head hex the best since they have more room, they are easier to remove with Allen keys or wrenches as needed, and they look clean
