Hi all,
Thought I'd add $.02 having just completed this swap on my kids' '88 4WD.
-- We put an AX15 from a '92 into the '88
-- The length of the two transmissions is identical in our case
-- Therefore, we reused the same drivelines
-- The crank bore for the pilot bearing in the '92 is 1.00" vs. 1.055" in the '88
-- We used the '73 CJ w/304 pilot bushing, which fit perfectly
-- We used the transfer case from the donor as well, so no spline issues
-- The trans mount and crossmember from the '92 worked great
-- We tapped the rearward holes in the frame (10mm x 1.5) and it lined right up
-- The exhaust hanger on the trans mount lined right up too
-- I've lost track of which shift lever is installed -- neither is a perfect fit
-- The '92 is a Sport, and the '88 is a Laredo, so the consoles are different
-- There is interference between the shift lever and the console in 2nd, 4th, and R
-- I guess we may need to find a shifter from a Laredo with the AX15
-- Any info on this would be appreciated!
-- We swapped the speedo gear from the '88 into the '
-- The trickiest part of the swap was the transfer case linkage
-- The '88 has the linkage crank mounted about 3" forward compared with the '92
-- The linkage crank is narrower on the '92, and the rods are longer on the '88
-- Neither bracket/linkage bolts in
-- We could have swapped out the bracket mounted to the underside of the tunnel
-- But this would have meant removing the driver seat and carpet
-- Instead, I ended up using the tranny-side bracket from the '88
-- I flipped it around and used it inside-out
-- There is a threaded hole in the AX15 that takes a 7/16 bolt in about the right place
-- I drilled out the mounting hole on the bracket
-- I pushed out the plastic grommet and put it in from the other side
-- (Actually, I ruined the first one and managed to swap in the one from the '92)
-- (Heating it over the drop light seemed to help)
-- Here's the combo: tranny bracket from '92 (flipped); crank from '92 (narrower); rods from '88 (longer)
-- Don't drop the cross member without disconnecting the exhaust!
-- We cracked the manifold (another major project awaits)
That's all I can think of.
Scott
