jeeptorino68
- Lebanon OR
get the hooks from the full size GM truck, and bolt them to the jeep tow hook brackets.
sideway shooks dont drop straps
swaybar mounts?!? :doh:
someone please remind me to RUN if these need to be used.
seriously, dude, don't do it...
You know so? i have been running it since last summer and have been tugged through Fordyce and haven't had any signs of fatigue in that area.. If its a bad idea, i will take them off. :dunce:
enough said, off they go.. Thanks guys!!
JK front upper and lower control arms...
you can either mount them up and stretch your wheel base... or make new mounts 6-8" back
So they fit the stock mounting points on both sides? How much do they stretch the wheel base?
If you stretch the front wheelbase, youll then have problems with the track bar and the steering, and the sway bar if you have one, as they will all need to be relocated as well. This is not a good idea. But relocating the rear mounts would be OK, but that would be very difficult as the uppers would run into the cab area. This is the main reason long arm kits dont have an upper control arm.
ummm... long arms DO have upper control arms... the only ones that DO not is Terra Flex
Just two lowers huh?.... sounds like a recipe for axle wrap to me.
i beleave you can swap in durango steering boxesanyone know of any better steering boxes from junkyards?
read something once about a J10 or J20 box?
