2001XJ
- Canton, MI
I believe that's exactly what Jeeperjohn is saying. Since caster and pinion angle are affecting each other directly, you'd have to find an angle that is a compromise. I.e. caster is not too far off but still acceptable and pinion angle is acceptable. Otherwise if you were able to adjust each independently such as you suggested (re-positioning the c's) then you wouldn't have to compromise.
Ah, gotcha
