scott in NH
Ok, I have a 90 2-dr that had a 1” sag going in the back and I wanted just a little more clearance for some 235/75/15’s. So I took Eagle’s advice and put a full length Rancho AAL in back and a 1” coil spacer out front. This evened out to a lift 1” all the way around and over 4 years later, it still sits the same and I like the way it looks!
Now I have a 2000 4-dr that has NO sag, but I would like to lift it the same 1”. Yeah, I know, I know, but I do not have inchitis and I do not wheel. I do load it up to go skiing, and ski traffic moves right along, so not losing road manners is very important (upside down in the median is not where I want to find myself).
I also tow a boat, but my tongue weight is probably only 75 lbs (I put it on the ball by hand) and the boat/trailer probably weights 1000-1200 lbs, but some of the “ramps” I use look more like trails (steep and rocky)! I also use fire roads/dirt roads to get to some of the rock climbing I do. That’s it. It is my daily driver and goes on road trips too, so I am not willing to make the compromises you guys do because I will never use it the way some of you do. In other words it is a luxury vehicle and I want to keep it that way while adding just a little attitude.
It has the 16” wheels, which I like, and I just want to go up one tire size to a 235/70/16. So, a 1” coil up front is obvious enough, but what is the best way to only get an inch or maybe 1-1/4” in the back considering how I really use my Jeep? Block, shackle or AAL? If I go with the leaf, do I leave a stock leaf out to not get the 2” or? What brand AAL (you guys seem to hate them all)?
As always, thanks for your help,
Scott
Scott
