cj11
- Easton Pa.
I have the same prob at the same mph. Tried everything said above my next step is going to be rotors. Has to be it.
No one said he needed a trac bar.but he should check everything on it, including bracket. and at 4"s you definately need a adjustable one!! period!at 3"s the oem trac bar is limited at 4"s it's worthless! see for yourself put a adjustable on with 3" springs then with the oem. and see for yourself..more to a adjustable trac bar than just centering your axle.the oem's bind on passenger side with oem coils!i run 2 xj's at 3"-4", on stock tracbars, neither have EVER experienced deathwobble....
the only jeep in the corral to experience dw was at 5.5 w/ a tnt tracbar....
jeep logic is differant than math.
ive been hearing this argument sinse my first day browsing naxja, its just not true IMHO....
get an alignment, or at least do a tape measure allignment at home for your toe in.
I won't disagree that an alignment "inspection" is a good idea, but I will argue that any lift over "xx" NEEDS track bar or alignment, I just completed a junk yard lift this weekend and have NO PROBLEMS (yet) I'm at least 4" (rear is almost 5") lifted and the only difference I find is a stiffer ride and the tiniest driveline vibe from the slip yoke. I guess my point is there are no hard and fast rules on an XJ, just a lot of dependable advice...
other than installing new coils and bastard leafs, with new shocks all around, I've changed nothing else...
I can guarantee you need a track bar at 4 inches unless you redrilled the axle mount. measure and see where your front axle is. The good thing about XJ's is you can align it in the driveway and be very close to where it needs to be.
* If you lift it you MUST align it its not even a question. Aligning an XJ is very simple and a very easy PITA possibly broken parts because ur xj came from michigan. DIY job.
the axle is offset to passenger side about 2 inches (thats eyeballing it) without a tapemeasure,
A rubber boot with a small hole isnt going to cause a shake. Now if the TRE was wasted then yes.
I think the small vibe is your shocks. You should go test them out one more time.
get an adjusable track bar and center the front axle that should take care of it
I used a skyjacker bracket with a 3in lift put the axel dead center. That should be fine with a 2 in lift there is some adjustment with them.
rusty's has an adjustable track bar thats 2-5" for 129. i think i'll get that one.
Have you learned nothing from this website?
Because its 4wp's...yeah, everyone hate's rusty's right? then why did the guys at 4wp's suggest me to go to rusty's for the track bar? they were like if we could carry them they would...
You don't remember correctly. Their trackbars strip out and break all the time.MaxxXJ said:but if i remember correctly, it was their lifts not their LCA/UCA's or trac bars.
