ArcticXJ
- Anchorage AK
Mounting coilovers to a unibody sucks. So...
Here's a few shots of whats been going on with the M.I.A. supafly cherokee:
The general idea here was to design a strut tower style tie in bar that would connect to two shock hoops, and tie into the frame for rigidity:
Noah, the mad scientist. Here you can see the very bottom of the shockhoops/frame plates, and the general suspension setup.
14 bolt. Not toooo wide.
Some test fitting, and preliminary mock up of the coilover axle mounts.
A better view of the aforementioned, and a complete look as to the design of the shockhoop system. The coilovers wont actually mount in the hoops themselves, rather up on the strut tower bar. The shock hoops actually serve most of their purpose as a structural reenforcement, tying the system into the unibody, and adding rigidity to the front end.
Every once in a blue moon, Professer Noah will accidentally lay down a half decent bead. This is one of the uprights that ties the strut bar into the top of the "frame" rails.
More to follow....
More to follow....
