Matt S.
- Fresno, CA
Vintage. not to neccesarily correct you, I agree that length differences will create a slight bumpsteer. But I disagree that a inverted "y" is going to help. I ran a inverted y after 3 stock setups and it was also in plane with the axle movement. and was same length might I add. Had such horrible bump steer and DW that I couldn't live with it. After the switch. Almost like stock to be honest with you. But this was my experience, others could be different.
But to anyone who wants to go and build something like this needs to really consider what they are going to demand out of it. I had had soooo many bad DW so many different times that I was going to make everyhting so it could not happen. With led me into a whole front end outer rebuild.
You need to do more than steering linkages. You need to consider frame rienforcement, steering box bracing, tract bar mounts (both upper and lower), plus many more things.
This is all IN MY OPINION though. I am of no expert or one that should be taken totally factual. Make sure to ask good thoughtout questions, and you WILL get exactly what you need. OK?
MATT
MATT
