CharlesS
- Quezon Province, Philippines
Here is the locker for the rear or my rig. http://www.ringpinion.com/ProductDetails.aspx?ProdID=1468
it also says "These units are not recommended for applications with high horsepower or large tires." are 33's considered large tires?
Most manufacturers of lunch box lockers and limited slip traction devices recommend their use with tires up to 32" because once you install larger tires their failure rate starts to increase.
You will get varying opinions on installing traction devices first in either the front or the rear differential, but since this Jeep is your DD and unless you plan on doing a lot of technical trails the rear locker will get you thru 98% of the obstacles.
Too many Jeep owners believe that a front locker is REQUIRED instead of gaining the experience of getting thru obstacles by picking the right line thru the obstacle.
Gain the experience first before jumping into a front locker.
