- Reno, Nevada
Looking at the specs of this Harbor Freight compressor, its pretty weak. But for $60.... you get what you pay for. Probably wouldn't be worth having if your tires are over 31". If it takes too long to fill the tires, the duty cycle will be exceeded and the thermal overload switch (assuming this one has one) will probably trip. So then are you going to wait about an hour (or longer?) for it to cool down before you can resume filling your tires?
I also would be skeptical about it being able to re-seat a bead, but it also depends on tire size vs wheel width and even how soft the tire is. I could not re-seat the bead on a 35" TrXus MT onto a 15x8 wheel with my Viair 400C compressor with a 2.5 gallon tank. And... I even used a strap around it. As I tightened the strap, eventually the tire just folded on itself instead of pushing the beads out any more toward the rim. I had to result to the starter fluid which did the trick!
