KSXJ
- Kansas City
I don't have vibes currently. But I eventually want to go bigger so would it hurt to install one now?
The splines "center" the flange not the bolt.It doesnt have to be perfect.kscherokee said:4.5 going to 6.5 I hope.
yeah, but what happens if you are not just perfectly centered on the whole
kscherokee said:I was thinking a front driveshaft. Wont that work?
kscherokee said:231 and a c8.25
Ramsey said:hack and tap is easy. just be sure to get a nice new bit to make a pilot hole. that output shaft is very hard to drill at first. mine is not centered at all. i even had to make the hole on the hack and tap slightly bigger so the bolt would fit, however i have had no problems with it. take your time use plenty of cutting oil and you'll be fine. chock your jeep leave it in 2wd with the rear shaft off already and put it in Drive while you cut the rear shaft, makes things a lot easier. mark it with some tape so you can see where to cut. took me 2 days just because i started late one night and no stores were open to go get a good drill bit. mine i had were not near sharp enough. shouldn't take more than a few hours with all the right tools though.
Id love to see a link/URL for that kit, Im interested!skyjackedxj96 said:RE now provides the Drill Bit AND the tap for you to make it a quick 1 hour job. couple of dewault cutting wheels and your set
kscherokee said:
