Andy in Pa.
NAXJA Member #180
- Downingtown, Pa.
Here is a perfect opportunity to replace your weak factory tie rod (or even that ZJ tie rod) with something that is virtually unbreakable. After being on the trails with a friend of mine a few weeks ago and watching him pretzel a ZJ tie rod (which, if you don't already know, is a very popular steering upgrade for the XJ's VERY weak tie rod), I decided to speak to a local shop called Full Circle 4x4 to see if they would be willing to do a group buy on a heavy duty factory replacement tie rod. This shop has made quite a few of these for other folks in the area. It is made out of 1-1/4" 7075 solid aluminum alloy round stock, with machined "flats" on the ends to put a wrench for easy steering adjustments. It also comes with jam nuts for the factory tie rod ends. It does not come with new tie rod ends though, you will have to remove your old ones or purchase factory replacements. THIS IS ONLY THE TIE ROD, NOT THE DRAGLINK.
The idea with 7075 Aluminum alloy is that it is a very light but very dense material. It will deflect if rammed into a rock, but this material has no "memory" so it will not bend or break like a similar steel tie rod. I have a crossover steering setup on my XJ, and I got this exact same material from Full Circle when I put it together. I have rammed it into rocks quite a few times and it is holding up very well. I just recently installed hydraulic assist, and it is attached to it. It seems to be holding up well, but I have not had a good chance to really beat on it yet since installing the hydro assist, so time will tell.
Typically Full Circle sells these for $130/ea with jam nuts, but check out our pricing below:
Qty 10 sold in this group buy-- $95/ea
Qty 20 sold in this group buy-- $90/ea
Here is Full Circles website for more info: www.fullcircle4x4.com
Go to the "Steering" tab in the menu on the left of their main page...
This price DOES NOT include shipping, I will handle this on an individual basis.
---THIS GROUP BUY WILL RUN UNTIL NOV. 28th, 2008.---
AFTER THE GROUP BUY ENDS--- I will collect the money through cash, certified check or paypal and handle the transaction with Full Circle, and I will make sure you get your tie rod(s). Keep in mind that this means that you will not see your tie rod for another 2 to 3 weeks after Nov. 28th.
If you have any questions, let me know.
Thanks,
Andy
Thanks,
Andy
