98XJSport
Destiny is the rising sun
- Western Maine
Notch the crosspin? Doing the gears on an 8.25, and was wondering which is the best and safest way. Grind a couple of teeth down, or mill a side of the crosspin. Going to 4.88.
Index your new ring gear so that the cross pin lines up with only one gear tooth.
Then you only need to take a little material off the heel side on one tooth and not two.
Should I grind on both sides of the hole or just one?
I have access to a full machine shop and people that have been making metal shavings for years and years, so I wasnt sure if having them taking it down would be the better option.
Only grind on one side, I ground on the side that the cross-pin retaining bolt is on
RedHeep is referring to the back side of one ring gear tooth and the front of another on the side of the case case that the crosspin bolt screws into.
