i just setup 4:56 gears in my 8.8 and i went to put the shafts back in and the carrier pin hits the ringgear and wont come out i was wondering if anybody has ever ran into this and what did you do.
On the first set of 4.56s what I did is grind off a little bit on the tooth of the ring gear with a Dremel to get the pin in/out.
The 2nd set, the ring gear ended up in a place that the pin is between 2 teeth, so I didn't need to do anything.
So either you could remount the re gear, grind a bit off the tooth, or you could always grind the pin.
