Tenny
- Houston, TX
great write up!
I'll be ordering some parts soon
So with the LED's in the instrument cluter, do they look a lot better than factory? Are they more crisp and readable and possibly brighter?
DanMan2k06 said:I definately think so. The readouts seem to be a lot more defined. It does take a little getting used to though. I put blue in my cluster, and for the first week or two I couldn't stop starring at them because they look so cool As for brightness, I would say about the same.
keep0njeepin0n said:i thought you said with the blue you couldn't see anything
tclapp_88 said:if you read what he wrote, he said he put blue in for the blinkers and he couldnt see anything. then he said he put blue in his cluster, which is where the gauges are and he could see...
keep0njeepin0n said:No, if YOU read what he wrote, he said he put them in the cluster!!!!!!!
^ This is correct. By using the specific color, it allows the most lumens to pass through the lens. I learned this the hard way. I tought hey, it would be chill to have blue blinkers instead of yellow/green. Not knowing that the color was actually produced by a cover on the cluster, I put it the blue bulbs and couldn't see anything...
